Re: esp-bas code 1330 Wackamole
I have found that some DTC after clearing the codes on the scan tool require that the ignition is turn off for 10 seconds then back on before you move the scan tool to the next page or process. If you just clear codes and move to next process the code will remain and not clear.
Thanks for pointing out that error 80-235. I'll make a note in my manual.
