Old Jan 6, 2025 | 01:35 AM
M60A3Driver
Default Re: How to Diagnose a Battery Drain
Originally Posted by Capt_TJM
PIZZA GUY, Thanks for the input. I re-grouped and retested the voltage drop across the fuses. All fuses tested at 0.001 mV to 0.005 mV on a lab grade DVM except #9, 0.330 mV. By removing the fuse from #9 the amperage across the battery drops to 0.020 amps. Drop the fuse in and I can hear the siren try to sound but it just buzzes a bit and the sound goes away but the 0.180 Amp draw remains. For now, I just pulled the fuse, the car is garaged for the winter. Somebody posted step-by-step instructions to get to the siren and remove it. I'll do that next time we get 40+ degree Temps here in Connecticut.
Thanks to all for the input, the forum works!
Hi,
You may be referring to a post I did on replacing the siren and cleaning the drains. The post is in 2 parts. You can bookmark them for future use if you find them helpful.
Here are the links:
LINK Alarm siren replacement & drain cleaning PART 1
LINK Alarm siren replacement $ drain cleaning PART 2
