Re: brakes questions
I would inspect the brakes, change hoses ( optional) , bleed wheel cylinders & completely replace all the brake fluid. If you have a manual transmission also bleed the clutch slave as it uses the same brake fluid in the master cylinder. Stop Tech Braided Stainless brake hose available at Amazon : part # front 950.35001 rear 950.35500
