Old Jan 23, 2025 | 06:28 AM
MarkWhit's Avatar
MarkWhit
Default Re: Radio & CD player or alternative?
Originally Posted by THETESTER
I sent you a private message, not sure if you have received it?
Also be aware that the various install sheets/ method sheets and PDF's you can get from other forum members are now not applicable to the UK variant(s) of the Kenwood units. As I have said in past postings, the methods used were brilliant and a great help at the time, but Kenwood UK now do all the work for us. I am politely saying with no disrespect to any other forum member(s)....ignore everything and just follow Kenwood's Instructions. I can clarify further if you wish by sending you the Kenwood install instruction sheets.
Cheers
Hi, stumbled on this thread while doing some research on head units for a 2005 roadster I'm picking up in a couple of weeks - it's been very useful!
I'm hoping you may be able to clear something up for me - I'm looking at the Kenwood marine unit (model is KMR-M508DAB if that helps) but wanted to check on the connections side of things, I've enquired with the retailer who have said it won't fit if the car has the factory fitted amplifier, they say the sound won't work if that's the case. I don't yet have the car to check if it has the amp, but that reply seems at odds with the info on this post so I'm probably more confused now!
Any further help is appreciated, thanks.
