MarkWhit
Hi, and thanks for the quick response!
Yes it's a UK model soft top/cabriolet/roadster, the standard model not the SRT6 version. I've found the silver marine version via eBay, a company called Dynamic Sounds. There doesn't seem to be much by way of choice of silver coloured head units but this model looks pretty good.
I am indeed in Lancashire so maybe not so far from yourself in Manchester - I'm just on the Lancs/Yorkshire border part way between Burnley and Skipton. Quite new to these forums but hoping to get involved with meetings/drives etc as time progresses, so any suggestions etc will be gratefully received!
Really appreciate your help with this, thanks.
Hope you enjoy the Xfire, not much goes wrong, but when it does it can be a problem to find parts. There are things you should get sorted, before you hit problems:-
I would do the following to be on the safe side:-
1. Change the serpentine belt - get a second pair of hands to help out, it will only take you two minutes once you have fathomed out how to release the tension on the belt.
2. Resolder the RCM - I work in electronics so it was dead easy for me to do. The RCM problem is a right pain in the backside.
There are other things to do and they are dead simple when the weather warms up.
If you require any info just give me a shout.
Cheers
