Re: Auto Transmission Drain Plug Allen or Torx
Just use a breaker bar so you have more leverage. I was able to loosen the bolt and drain the trans pan before removing it. Sometimes I tighten the bolt and then loosen it. You can also spray some penetrating spray on it and let it do its job.
