Old Feb 13, 2025 | 08:52 PM
M60A3Driver
Default Re: New owner of 2004 crossfire/ tranny oil question
Originally Posted by C Cole
Owner's manual specifies a transmission fluid and filter CHANGE, NOT A FLUSH, at 80,00 miles, with no further service nor even checking of fluid level. Some argue that a flush might dislodge debris accumulated into firm globs, which can then migrate to small control orifices, maybe jamb valves but a drain without flush likely allows these globs to remain in place., Cap of dipstick tube to be reinstalled. I DO NOT KNOW IF THIS CAP IS TO MAKE AN AIR-TIGHT SEAL WITH THE TUBE. Sealed-for-life automatic transmissions and hydrostatic drives are common these days. I have a sealed transmission on a hydrostat lawnmower going strong after 20-plus years of use.
Why are you quoting me/barking at me? I didn't ask the question.
I agreed with the mechanics that it was a good idea not to mess with the transmission. I suggested he refer to his owner's manual. He could also download a service manual from the link I posted.
Sealed for life, doesn't mean lasts for ever. The transmission fluid has to be checked and at some point will need to have some more added.
By the way, the cap is locked to keep regular people from checking their transmission fluid. This way Chrysler could charge a ton of money to do something that you could do yourself.
You can get an aftermarket dipstick and a replacement cap for less than $30.00.
