Old Feb 14, 2025 | 02:05 AM
Myopic's Avatar
Myopic
Default Re: The engine in my Crossfire is sweating quite a bit...
Originally Posted by Wadsworth
In another post you just had the oil changed. Did you have this issue before the oil change?
Yes.
Originally Posted by dcskmail
Definitely re-torque the valve cover bolts along with re-sealing the breather covers
Ok. Thank you.
They were sealed with silicon when the engines were made.
Does it have to be a specific sealant/silicone from a specific manufacturer?
I decided that along with replacing the sealing compound under the breather covers, I would also replace the gaskets under the valve covers.
So that I could do it all in one go. What do you think ?
Can you recommend good gasket manufacturers to buy ?
