Thread: Hesitant start
Old Feb 16, 2025 | 03:01 PM
ajchicago's Avatar
ajchicago
Default Re: Hesitant start
So, a local salvage yard had 7 crossfires… so I spent entire week salvaging parts to store away in shed. I replaced the starter with a used one from a 2004 crossfires TYC I think was brand I may be wrong but something of the sort/similarly named. The car fired up like boss. I have started it multiples times this week and driven it a good 200 miles now. I cleaned/degreased entire bottom of engine & transmission. From what I have seen so far after cleaning under… is that could possibly be a small lower pan leak/seep… but definitely the Oil Level Sending Sensor… which I’ll have to drop pay to remove & inspect… probably just a new o-ring seal… but, I salvaged 6 used ones from yard this week regardless… I’ll keep posted if replacing ring & new gasket/seal on lower pan eliminated this fluid leak that’s been wetting everything. But so far car is running great.
