A couple of days ago, I installed the Needswings oil catch can. Easy setup, got the lower pin into the hole on the body -below the power steering unit- and screwed the upper end, making use of the available hole. Let it sit in there and the rest is a piece of cake.
From the driver’s position, the two first tubes go to each valve cover and the farthest tube into the Y shaped connector on top of the throttle body.
Picture top-to-bottom tubing. Top tube: passenger valve cover connection. Middle tube: driver's valve cover connection. Bottom tube: Y-shaped throttle body connector (driver's side). I bent the heat shield slightly to avoid slicing on the tube. As for the passenger's side Y connector, use the plug provided to block it.
The only qualm was the tube clamps.
Too snug to start with, IMHO. Some pulling and bending later (PITA) got it all installed. I hope my engine gets less debris back into the motor to be burnt again. Looks snug, fits ok, does not diminish the looks of the engine in the least. A happy bunny here...
