Old Mar 6, 2025 | 01:47 AM
M60A3Driver
Default Re: Rough Idle no codes
Originally Posted by Wazy300
Hello crossfire family, My 05 Auto limited roadster has recently been having quite the rough idle (extremely aggressive like whole body shaking) at stop lights, however the second i hit the gas she's smooth as butter.
right over 100k miles, not showing any codes other then brakes. Have looked for vacuum leaks visually (still need to do a smoke test), checked air filters which were almost perfect. Plan on checking spark plugs, maf and icv later today.
From what ive gathered browsing forums these seem to be the most common of the issues, As I know this is quite a common problem any tips of advice would be much appreciated.
  • Vacuum Leaks – Cracked hoses, intake manifold leaks, or PCV system issues.
  • Dirty Throttle Body – Carbon buildup causing improper airflow at idle.
  • Failing Idle Control Valve (ICV) – Sticking or dirty ICV affecting idle stability.
  • Dirty or Failing MAF Sensor – Incorrect air-fuel mixture causing idle issues.
  • Bad Spark Plugs or Ignition Coils – Weak spark can cause rough idle but smooth driving at higher RPMs.
I was on the Benz forum a while ago and remembered this thread: LINK to Benz Forum thread rough idle
One member suggested this to test it, (second post down in the thread): When the engine is cold and off, take the serpentine belt off. Check the pulleys, especially the idler and tensioner.
Then while the belt is off run the car for a minute and see if it still idles rough. Do not let it warm up. (This is up to you if you want to try it).
He also mentions that there was a recall for some US harmonic balancers. He didn't give what years this happened.
It's worth checking out the thread, though.
Another thought is a clogged catalytic converter.
