Old Mar 11, 2025 | 05:56 PM
DTMenace's Avatar
DTMenace
Default Re: Transmission Dipstick Stuck
Originally Posted by stlouistrucker
I was checking the automatic transmission fluid with the 8863B special tool. It went in but will not come back out. What do I do now?
stlouistrucker
I googled the part# you mentioned 8863B, with no reference to Mercedes Benz (see Below). Is this part a traditional flat type of dipstick used by older cars? Did you stick this type of dip stick into the top of the transmission tube cap, this causing your issue with a STUCK flat dipstick? The true transmission dipstick looks like the oil dipstick that came with your car, just a different length to measure the tranny fluid. Once the transmission fluid has been checked, the stick must be removed and the cap must be reattached, if damaged, must buy a new one. This is a Mercedes Benz part, since the Crossfire you have is essentially an MB SLK320 (R170 and the Crossfire is a 193).
Since you've been unsuccessful, take it to an independent Mercedes Benz shop (not dealer) in your area for help.
Good Luck....
Dennis
DTMenace
To check transmission fluid level for vehicles using a tool with part number 8863B (like Chrysler, Jeep, Dodge, and VW), you'll need a dipstick tool, insert it into the dipstick tube until it bottoms out, remove it, and read the fluid level, ensuring not to leave the tool inside.
