Old Mar 12, 2025 | 04:06 PM
amx1397
Default Re: Crossfire builds
good luck,, tried the studs a bout 14 years ago they didn't work then and they will not work today, because
\U only have 6 to 7 threads to work with, stay with lug bolts. the lug bolts on your new wheels ,,,stick i lug bolt
into the rim make sure it sticks through no more than 1/2" or it will hit the emergency brake cable and if U
have an older car it may hit anyway, my rear tires with stock rims are 275/35x19 so with your rim u can go
wider and taler just do not get a tire taller than26.7 tall it will rub on bumps and corners.
if U R not racing then spacers are ok but,, this car does not like spacers.
owner of the worlds fastest crossfire 10.55@132.just do not have drag slip but do have this one.
