Old Mar 16, 2025 | 09:39 PM
M60A3Driver
Default Re: Climate control blowing warm air.
Originally Posted by xintersecty
I have the same issue. I just recently saw a post involving Svengoolie and rebuilt duo-valve. He took the rebuild of the duo-valve to a whole new level compared to my rebuild job. Wait a sec, you are the famous Svengoolie! LOL! Nicely done there. I have three theories as to why there is "hot air". 1) There is a hot/cold deck mixer and a possible vacuum leak causing the door to flip to the hot side. 2) The climate control system is farked and just turns on the duo-valve flooding the cabin with unneeded hot air. 3) Almost like the theory 2, but the coils in the duo-valve are failing.
Does the duo-valve fail open? If it fails close, then just unplug the duo-valve.
Thanks about the rebuild post! LOL
I'll try unplugging it and see if there's any change. I'm also going to check for voltage. I might just bite the bullet and get a new one.
