Re: Junk Yard Motor Swap (Blown Head Gasket)
pizzaguy
I asked the guys at the MSS this question years ago - the answer is that if it is the same model (N/A vs SRT) you are fine, just DO NOT change the ECU, leave all electronics alone.
Just swap the engine.
IIRC, with the automatic, you can transplant the TCU or not - that is your option. But I admit I can't remember for sure, seems like they said to NOT to changing TCUs.
@GannyX , what do you say, James?
thanks pizza so basically N/A as in base or limited motor will work without changing any electronics? Junk yard confirmed out of a limited automatic
