Thread: ECU damaged
Old Mar 24, 2025 | 05:13 PM
M60A3Driver
Default Re: ECU damaged
Originally Posted by Pezcop
I have a 2005 SRT6 crossfire. The engine was having trouble. I pulled the ECU and saw that one of the areas that you plug the wires into it has several pins bent or broken. I sent it off to be fixed and they sent it back saying that it was too damaged to fix. I had previously had it tuned through MSS. No idea how the pins were damaged. Any suggestions on where to go from here?
Thanks, Don
I'm not 100% sure about this and hopefully someone else will chime in, but I think you can get an ECU from another car and it should work.
It has to match the car that it's coming from. Example: if you have a 2005 SRT6 Coupe it has to come from an SRT6 Coupe. If you have a limited roadster, it has to come from a limited roadster.
