Old Mar 25, 2025 | 01:28 PM
zip439's Avatar
zip439
Default Re: What else to replace on major proactive maintenance?
Originally Posted by Distiller
I need to replace the coolant expansion tank on my '05 roadster limited, 106k miles.
Also have a new thermostat to install and thought I should replace the water pump and once I'm into it that far might as well replace the serpentine belt, idler & tensioner.
And with all that removed and out of the way I might as well replace the alternator (battery too).
My question is am I missing something?
Is there a coolant temp sensor or anything else in the glycol system?
Thank you!
Be advised there are a number of different length screws when replacing the water pump. Be alert as to which goes where. I suggest you place your new pump near your work place and as you remove the screws from the car place them in the correct spot on the new pump. Then when you install that new pump you will be certain to get the correct length screw back in the car where it belongs.
Also it all goes a lot easier if you remove the electric fan completely off the car before working those items you intend to replace.
