AC changing?
Going to vac my system down. Will be changing the filter/dryer. On my older Chevy systems it is often necessary to jump the low side pressure switch to get the correct amount of refrigerant into the system. Is there a similar process on the crossfire? Where is the switch?
thanks.
I was going to also replace the expansion valve, but I’m hoping it was just iced up last I tried as it seems like a pita to get to.
