Misfire codes above 2700 RMP
Apr 15, 2025 | 10:30 AM
permalink
taschwen
Mar 2025
Draper, Utah
I have a 2006 Crossfire Limited with about 103000 miles. I runs and idles great, but when I increase the RPM's to above about 2700 rpm, the check engine light comes on with P0300, P0301 and P0306 - misfire codes. Here is what I've done:
Engine compression test - lowest was 165 psi (only one) others were all around 170 to 172 psi.
replaced Cam shaft and Crank sensors - with Bosch
I didn't change the spark plugs, they look new
checked coils - exchanged coils around to different cylinders, but still got the same codes
checked for blocked cat's (first I disconnected them, and then even put it back together and tried just taking out the O2 sensors)
checked for vacuum leaks and replaced old cracked hoses (I did not do a smoke test, but may if you think it is necessary)
When I got it, it was missing the EGR valve, but I got one from our local pick-n-pull and installed it
O2 sensors seem to be working.
Fuel pressure is at 55 psi
I had the fuel injectors cleaned and tested
Anything else??
Any suggestion would be greatly appreciated!!
taschwen
View Public Profile
Send a private message to taschwen
Find all posts by taschwen
