Re: Misfire codes above 2700 RMP
Hi, sorry to hear about your problem. Do you get the misfire at 2700 rpm under load, or parked? Sounds like it could be the fuel injectors - when you say you cleaned and checked them - does that mean you removed them? Did you examine the o-rings around the injectors to see what shape they are in? You can carefully spray carburetor around the injectors to see if the engine reacts (maybe spraying water or a smoke test is safer).
Good luck
-Jerry
