Old Apr 20, 2025 | 11:42 AM
M60A3Driver
Default Re: P2030-04, p2037-04, p20cc-08, p2036-04, p203e-04
Originally Posted by Bzak1pgh
05 Chrysler Crossfire base. Drove to town and back, car was at idle in my driveway then the coolant fan kicked on extremely high. Dash gauges lit up like a Christmas tree. I turned the car off and let it sit for a few minutes, then proceeded to start it back up and absolutely nothing...no click, no fuel pump engagement, absolutely nothing. Figured might be battery....nope. Hooked up the scan tool and wella... I'm just looking for diagnostic help, what the check what to fix. I'm pretty sure 1 or possibly 2 issues is causing the rest. Is it my gear shifter??? I've been having trouble getting it in to just, Reverse and Park, for quite some time. Any help if someone has some time to take, would be greatly appreciated!!!
It sounds like your RCM went bad.If you have a spare, or can borrow someone else's swap it out. When the fan speed goes crazy, that's usually it.
As far as shifting, that could be your conductor plate.
