DAS System shutoff
Recently went about getting my steering wheel rewraped in alcantera fabric, You must remove the airbag when taking of the steering wheel quite obviously. And when replacing I walked away halfway through and forgot to plug in the airbag connector, Blanked and started my car just excited to try out the new steering wheel, and sparked an array of issues with the SRS, and DAS systems. Have Cleared all of the srs codes but just wanted to confirm, As to not make any mistakes with the Anti theft systems. How I should go about this
ECM is reading " Start Enable of DAS Not sent" so more likely then not this should be my issue, however on the of chance one of our members has made this mistake I figured id ask.
Have seen mention of a "learning period" for our cars electronics systems after clearing codes. I believe it was to leave your key in the on position without the car running for 10 minutes ?
2005 Limited coupe convertible
