Old Oct 18, 2006 | 07:09 PM
BRappaport's Avatar
BRappaport
Default Re: Roadster trunk question
Originally Posted by buggy4crossfires
Just dropped my partition for the first time since I own the car. If you bend down and look in you can see the whole shooting match. Can the partition be hung further in to cover the motors etc. or is it removable? I'm afraid to start fiddling with it as I've had no problems with the tops function and I'm not looking for any now.
With the partition in the up locked position...it allows you to lower the top which would rest in the stowed position behind the partition.
With the top up...the partition can be left in the up position...giving 3.6 cu feet of trunk room up to the partition...or you can lower the partition and fold it forward where it velcro's to the back wall of the trunk. In this position...you now have 7.8 cu ft of space in the trunk...but in this stowed position...if you now look inside to the sides of the trunk...you can now see wire harnesses, and other exposed frame supports, etc that is not covered like the rest of the trunk...maybe I am missing some cover panels. Can someone verify what you have. Is this normal?
Thanks...Ben
