Old Apr 30, 2025 | 06:30 PM
xfClifford's Avatar
xfClifford
Default "Slight hesitation" during acceleration
Hey all, one of my personal Crossfires has been giving me some crap. I'll try to keep it short but informative.
Type of car- 2007 Roadster, automatic trans, 92,000 miles. Owned for 10 months, bought with 87,000 miles.
Parts replaced in that time- plugs and wires, fuel filter, vacuum hoses, MAF replacement, CPS replacement, RCM replacement, (used but working) coil replacement, fluids, oil level sensor, oil pan resealed, VC & breathers resealed, all normal maintenance-y items us crazies tend to do. Replaced aging battery with a new one and replaced alternator with a new Valeo unit due to an over voltage issue while stored for the winter.
Issue- on a cold start and run, the car stumbles/cuts off during all types of acceleration and it'll last approximately 3 miles before it stops, never to do it again until the car is fully cooled off. It's more of a "bucking" feeling, kind of like fuel cut off or power loss, and lasts maybe half second each time it does it.
Tests Performed- scanned for codes- NONE & none stored (used a Launch Millennium 90 Pro), fuel pressure tested and found it to be a little low at the key on position, changed the filter which corrected that anomaly but did nothing for the bucking. Visual inspection of all hoses, replaced breather hoses, T-junction, MAF housing to breather hose. Opened the RCM/ECU box and visually inspected wiring. Decided to replace the RCM "just in case". Changed the CPS just for fun.
In a desperate move to find and correct the problem I googled the symptoms and just like when you google your cold symptoms, I found all sorts of possibilities ranging from internal engine issues to a failing transmission. I bought a valve body and installed a TransGO kit along with a new OEM conductor plate and new shift solenoids. This was the only thing that seemed to lessen the bucking feeling but it's still there. I really don't think the issue is in the transmission as it feels very much like fuel cut off. Feels like someone shut the car off for half a second then said "just kidding" and turned it back on. Very odd, very random event. Sometimes it'll do this right from the moment I throw the car into drive and other times I can get a quarter mile before the bucking starts.
Im really at a loss and don't want to throw parts at it anymore. Any advice would be appreciated! Pic of the car for attention
