Old May 20, 2025 | 02:27 PM
ZERACER
Default Re: Replacing of the drive shaft support and the rubber ends of the front stabilizer
Quote from AMX1397:
first the drive shaft is balanced "0" but there is a I (eye) single i on 1/2 and two II and the single goes between the two,,
there is nothing to show you that you have the line up but again the drive,, each1/2 of the drive shaft is balanced 0
I have used 1/2 from a srt6 and the other 1/2 from a limited. Blow this pic and u can see the notches.
Rear drive shaft/U-joint-p1010592.jpg
ok go to https://www.crossfireforum.org/forum...rive+shaft+amx.
then go to post 5,,,, blow up the pic the picture on the right. jim
