Old May 28, 2025 | 11:22 PM
GraphiteGhost
Default Re: The pin and spring out of the key ignition
Danmancdn, If your posting what you did to the ignition assembly, that's GREAT! Now, please mark this on the inside fuse cover on the left side of the dash (drivers door open you'll see two screws, unlock those and you'll see all the lamp module fuses), take that door cover and mark it on the inside showing you have done the sticky key fix. This will tell any future owners the sticky key fix was done (so they don't open it all up and try to do it). Of course, I hope your ignition is working correctly? You'll be finished with the job when you document the work inside the headlight module fuse cover. Have fun!
