Originally Posted by rakoom2002
hey andrew do you have your igniter and ballast mounted to the frame on the passenger side? I don't see any screws? if not, would it be bad idea to drill small holes in the frames and then put some sheet metal screws into it to mount?
~ i used the supplied double sided tape... just clean the surface with rubbing alcohol first for good adhesion.
the tape holds great.
this is the route to go imo.
drilling into metal = future rust imo.
