Old Jun 3, 2025 | 12:34 PM
chargerwayne's Avatar
chargerwayne
Default Re: Battery drain and esp bas problems
Do you refer to connector B pin 4? If the relay is not stuck closed, the issue is in the ECU. You can prove this by unplugging connector E, if the current drops to zero, the ECU is at fault.
Automatic or manual? And what year? (There are differences in wiring between 04-06 and 07-08; and manuals are not the same as autos.)
2004 Automatic
