Old Jun 25, 2025 | 10:20 AM
WHski's Avatar
WHski
Default Re: '20 SLC300 Brake Wear message
Hey thanks for the quick reply.
Yesterday's "activity" was taking her to the dealership, first they checked the pad wear, (which I knew shouldn't have been a problem) "nope pads are okay, and sensor shouldn't be sending alert", so then they went onto "must be a failed brake sensor" changed that out, still had the alert. In the end, turns out a chipmunk or mouse chewed at the wire bundle running along the top of the frame, behind the right front wheel well, and chewed off one of the wires in the brake senor lead bundle on the engine side. GRRRR!!!! They resoldered the wire and taped it all back up, but as you know not an easy place, no room to work in!!!
