chargerwayne
In searching for my battery drain problem I found a draw on the rcm fuse for the engine control relay. I opened the module up and the relay contacts move freely. The battery will go dead in a couple days from this. I unhook the neg battery cable at home and make sure the hood doesn't latch.
The esp/bas light comes on as soon as I touch the brakes. If I restart it without brakeengagement and use the cruise control for at least an hour of driving the light goes out ,brake light works, cruise works for maybe two starts and back to esp bas lights.
I'm having the same issue, but we thought our draining issue was a different fuse. Sadly that fix didn't last. Here I am a year later and still getting a battery drain. Did you ever fix your issue permanently?
thanks,
Steven
