Old Jul 3, 2025 | 11:18 AM
208james@gmail.com's Avatar
208james@gmail.com
Default Re: Exterior bulb light
Hi. My exterior light out indicator has come on but all the exterior lights seem to be functioning. I did change the two license plate bulbs with led bulbs a few years ago and have not had any problems until now. Is there a way to check the various exterior bulbs without removing and replacing them one at a time. Does the warning light automatically go out when a bad bulb is replaced or is there some sort of reset required? If I can’t determine which bulb is a problem would a simple voltage test with a multimeter at plugs or possibly at the various lighting fuses help to determine is there may be another problem other than the actual bulbs.
Any suggestions are appreciated.
Thanks
Jim
