BoB Fenn
Hi... I was never able to get a final answer from this group regarding the loss of my door locking function on my FOB. Okay... I live with it. But, now neither power seat will work. I checked the fuses and since there was NO power to either side of the fuse, I was "CONfused". I did find "some" fuses with power on both sides (good fuse), but the fuse numbers 21 and 22 for the two seats have GOOD fuses, but NO power, thus the seats do NOT operate. Oddly, there is also NO power to the wipers, yet they work fine! What the hell is with THIS???? What's the point of a fuse if it's not being used? If someone can help me here, that would be great. If not, then I'm going to go directly through from the battery over to the fuse box (through a 30amp fuse) and power it up with a clip... then see if I can move the seat. Any other suggestions? Thanks! BoB in Mass.
Hi
@BoB Fenn , most likely it is the power seat relay located behind the dash. This link covers how to replace it:
Power seat relay replacement
Some things will not have power unless the key is in the on position. Like the wipers, brake lights, horn, etc... That might be why you're not seeing power on some of the fuses.
As far as the key fob, have you replaced the battery? If so have you done the re-sync procedure. The top battery in the fob might not be making contact with the prongs in the corner of the key fob.
Check out the video below:
