Old Jul 6, 2025 | 02:19 AM
  #45 (permalink)
M60A3Driver
Default Re: AC suddenly blows hot air, any suggestions?
Originally Posted by g3air
I thought by pressing "quick reply" I was responding to a specific post - apologies
It was in reply to:
I also checked on the Fuse 15 and it is intact. Given that the A/C appears to be working fine if the Fan speed is at maximum (for the past week and she drives it at least once a day), does that indicate anything pro or con regarding replacing or repairing the control module? Is the 30 minute "flush" still recommended?
Just a thought, try putting your fan speed dial at 3 or 4. Then tap the dial. Does the fan speed change without moving the dial? If it changes you might have a bad potentiometer in the dial. That might be why it works only at maximum.
