Thread: Convertable top
Old Jul 9, 2025 | 11:46 AM
M60A3Driver
Default Re: Convertable top
Originally Posted by Jlupi
After battery change top no longer goes down. Press button windows go down then beeps. I have tried bypassing trunk switch and manually put up and down many times to reset. Will go up once put down. Any ideas or shops that can look at in northern NJ?
I'm in north New Jersey, close to Fairfield.
Here are some no cost things to check:
Swap out fuse #5 in the engine fuse box. That's the fuse for roof control.
Check your hydraulic fluid in reservoir behind drivers rear wheel in trunk.
Try disconnecting the negative side of the battery for 5 minutes then reconnect it.
Check the micro switch on the rail above where the passenger's head would be.
Here's a trouble shooting thread that might be helpful. Convertible top sensor trouble shooting.
