Old Jul 10, 2025 | 09:29 PM
M60A3Driver
Default Re: 2005 Crossfire Limited Alternator Replacement
If you decide to replace the alternator yourself, disconnect the negative battery cable first then the positive cable. Then insulate or secure the cable ends away from the battery.
Maybe I'm over safety conscious, but why take the chance of a loose wire sparking while removing the alternator?
When you're done connect the positive cable first then the negative.
