Old Jul 11, 2025 | 01:33 PM
BrushRoadster!'s Avatar
BrushRoadster!
Default Re: DIY Eccentric Bolt Install
OK. The tires are worn severely on the inboard edges. Now is this NEGATIVE camber, or POSITIVE Camber? I have the 4 bolt replacement kit How do I want to place the washers to correct for this inboard severe wear. I could find NO alignment shop in Tucson that would replace the bolts. They can ADJUST them, but not INSTALL them. So, I have to put them in myself, and now I need to know which way to install them, so I get the car off to the best possible start.
Also, since when the shop guys look at their books, it will tell them there is no adjustment for the camber, how do I get them to look at and adjust the camber so my tires wear evenly? In other words, I put the new bolts in, but how do I get the shop I go to to pay attention to the fact that they are NOW ADJUSTABLE, and they NEED TO RESET THEM? The tutorial really isn't clear about how you want to set them initially, either. Especially if you have severe tire wear on the INBOARD EDGES of the tire.
