pizzaguy
That relay is used by the SKREEM to flash the turn signals, nothing more. It is not your problem.
Thanks for your continued input Pizzaguy. It takes me a minute to work through the process and try to understand the system, and I appreciate your patience as I worked my way towards getting your initial conclusion that part of the SKREEM appears to be bad. It certainly seems that the process of elimination has reduced it down to that. Time to look at the SKREEM rebuilding options I guess.
Thank you all for the thoughts and guidance.
