Old Jul 26, 2025 | 08:21 PM
M60A3Driver
Default Re: My turn. Finicky top
Originally Posted by Ricktara
Yes fluid is near full.
Just did the manual open and close with engine running. No change
It will go up completely from start to finish with closing windows on its own.
It will not attempt to open after I pull d ring and Windows go down hitting switch it beeps.
If I initiate manual open by unlocking hex in trunk and lifting back window and then releasing tonneau cover and at that point if I press the down switch it will put top away and close and latch tonneau and put windows back up on its own.
Have you tried bypassing the trunk divider switch?
just short the wires together and try it. If it works the switch is bad.
