Old Oct 20, 2006 | 01:16 PM
Eracer76's Avatar
Eracer76
Default Re: Please Help!! Head unit uninstall
The radio you have should be held into its metal can/sleeve by 4 small phillips head screws.
To get to them, remove the face plate, then the trim ring, then you'll see the screws, two on each side, remove them and the radio should slide out of its sleeve.
Then if you need to, you can remove the sleeve by unbending the tabs that hold in.
