Gas in the Charcoal Canister
Aug 13, 2025 | 10:11 AM
25
permalink
xintersecty
Aug 2023
346
205
Columbia SC
Re: Gas in the Charcoal Canister
OK Everything has been put together. I need to put gas in the car run it a bit and then check for leaks.
First I tested the charcoal canister. I needed to identified the ground wire which is typically the brown wire. Ground goes to pin two. Hot goes to pin 1.
Charcoal Canister Pressure Valve
I used two small wire connectors that are typically used for breadboarding in the electronics world.
Green hot, blue ground
I used a 12 volt source and made sure it worked.
Unfused 12 volt source and valve
The charcoal canister shutoff valve is normal open.
Open
Under test
Closed
So the valve checked out. So I put that back on the canister and into the car.
I put everything back together.
Fuel pump and fuel filter
Used fuel line clamps instead the screw clamps when somebody replaced the fuel filter.
M60A3Driver
xintersecty
View Public Profile
Send a private message to xintersecty
Find all posts by xintersecty
