changed the water pump for fellow XF owner
Old Oct 23, 2015 | 08:22 PM
rmcdaniel12's Avatar
Default changed the water pump for fellow XF owner
Had a fellow XF owner tell me that her water pump pulley was very wobbly anda bunch of fluid was resting in the belly pan. I seen the pulley assembly was very wobbly indeed and when i took the water pump off the blades on the backside of the pump marred the surface up pretty bad. I took Woody's advice and traced the replacement water pump on cardbooard and stuck each bolt thru the cardboard as i removed them from the block. Theres no way anyone would remember where each one goes as they are all different lengths and some are M6 and some are M8. I wrote 18 bolts on the cardboard but theres actually 19 bolts. I'm sure someone would have pointed that out. Heres a few pics.
Old Oct 24, 2015 | 12:02 AM
pioneer4x4's Avatar
Default Re: changed the water pump for fellow XF owner
Originally Posted by rmcdaniel12
;I took Woody's advice and traced the replacement water pump on cardbooard and stuck each bolt thru the cardboard as i removed them from the block. .
Excellent idea!
Old Nov 24, 2015 | 05:41 PM
CrossfireZona's Avatar
How many miles on the engine, and was the bad WP the original OEM?
Old Nov 25, 2015 | 08:12 AM
Good idea, but I find it easier to just place the bolts into the new water pump as you remove them, then once the old pump is off, swap them back. Then do the same as you install the new pump.
( no drawing skills ( which I lack ) involved. )
Zoodust
Oct 22, 2015 01:04 PM
onehundred80
Other Cars Etc
Oct 13, 2015 09:20 AM
caseydeankopp
Oct 7, 2015 03:17 PM
FUBU
Mar 19, 2011 02:45 PM
SRT4man
Jul 1, 2010 12:35 AM
