Park lights on one side?
Old Jul 22, 2016 | 11:59 PM
rlohrey's Avatar
Default Park lights on one side?
I was at my favorite watering hole the other night and I had a few people tell me my park lights were on. It was daylight when I parked. When I got outside, yes the park lights were on, but just the passenger side lights.
I cycled the fob a couple of times and the lights remained. I checked the headlight switch and it was in it's normal 'off' position. I cycled it a couple of times and still, the passenger side lights were on. I cranked the engine, let it idle for a few minutes and the killed engine and removed key. The lights were still on. I cycled the light switch again and they went, and remained off. Quite a puzzler. Hours later I left and in doing so noticed the tire pressure idiot light was on. Drove on home and the next day went out and found rear passenger tire low. As in zero. I aired it up and heard air leaking out as fast, almost as I inflated. Pulled tire, had fixed and after driving for 30+min tire pressure warning light went out.
My question: were the lights on because of the low/flat tire? As I said in my intro, I bought the car, 07 Roadster Limited in the month of May. I've read much on this sight and think it's wonderful for us owners. However, I've not been able to find any symptoms that relate.
All is well....except the lights being on for that short time that night.
Old Jul 23, 2016 | 01:22 AM
Red Runner's Avatar
Default Re: Park lights on one side?
If the headlight switch is not at the O vertical position then the next position counterclockwise is the passenger Standing Lights position. This is the only way I know for the passenger side lights to be on with the car shut off. If left on for a long period of time they can run the battery down. And no, this is not related to your low tire problem.
Old Jul 23, 2016 | 07:51 AM
The ICM can be turned left or right, each way has two positions, the left will turn on the parking lights on the left or on the right. It is a European thing, you park with the lights that are on the outside, toward the center of the road, the ones nearest the curb are not lit.
Old Jul 23, 2016 | 12:28 PM
??? Has there ever been a case where water in the trunk modules caused the park lights to light up? ???
Old Jul 24, 2016 | 07:40 PM
OK, you have me there. They are controlled to go off by the pump when the lights have been on. My answer would be that possibly they do not turn off or even on if there is damage to the pump.
How's that for a sitting on the fence reply?
Old Jul 25, 2016 | 02:06 PM
Dave, you sit on a fence very well, just don't fall off! I almost always invoke deep thought processes. Going through the electrical diagrams in my 08 manual book 2, for many hours (cross-checking page upon page and then some more) I see it IS possible. Is it the cause of this problem, I don't know.
Old Feb 18, 2018 | 02:55 PM
mariontr's Avatar
Ok, I know this is an old post but yesterday I turned counterclockwise on the headlight switch and the passenger Standing Lights as indicated above does not come on? Anyone had this issue?
Old Feb 18, 2018 | 11:09 PM
rbracy10406's Avatar
I have not. Have you checked fuse 7 in the headlight switch? This goes to the right side standing lights. Does the left side work for you?
Old Feb 19, 2018 | 10:15 AM
You know there are two click positions to the left and they turn on the passenger or the driver side parking lights. I am just clarifying the details.
Old Feb 19, 2018 | 10:17 AM
mariontr's Avatar
Yes the right side works, turns to the right and all comes on it is when turned to the left, nothing happens. I did not check the fuse but will tonight when I get home.
Old Feb 19, 2018 | 10:21 AM
mariontr's Avatar
I will double check that onehundred80 but I swore I did that but you can never tell, my brain said I did and probably did not
Old Feb 19, 2018 | 10:22 AM
I would imagine if the fuse broke they would not come on at all, otherwise there would have to be two circuits for those bulbs.
Naturally the bulbs or sockets would have to be in a working condition, have you checked these?
Old Feb 19, 2018 | 04:34 PM
mariontr's Avatar
Talking Re: Park lights on one side?
Well onehundred80, you are correct, only clicked one not twice and when I did it worked
Caleb
Oct 14, 2016 11:01 PM
Caleb
Jul 4, 2016 01:01 PM
srt10
Jul 3, 2016 11:37 AM
mraehorn
Jun 16, 2016 02:54 PM
Ron Dube
May 19, 2016 04:43 PM
