door lock pump
Old May 26, 2017 | 05:50 PM
wap's Avatar
wap
Default door lock pump
The vacuum pump that lock and unlocks the door is running longer than it use to. Could this be because of a leak or does it point to a more serious problem?
Old May 26, 2017 | 05:57 PM
Default Re: door lock pump
If it was mine I think I would take the cover off it and watch it while I actuated the locks. I think that there must be some form of sensor that determines the time the pump operates, probably based on pressure.
Old May 26, 2017 | 07:46 PM
daveesrt6's Avatar
I would check for a water leak / moisture under the pump .
The spoiler and fuel door seals can fail and let water in.
Let us know...
