Help with P2098 CODE
Old Oct 1, 2017 | 11:57 AM
roychez's Avatar
Default Help with P2098 CODE
I had my cel checked at the auto store and this is what was told to me Post Catalyst Fuel Trim System Too Lean Bank 2
He suggested I get a diagnostic on my car any thoughts on this.
I was going to pull the TB and clean and replace the O ring first before I buy the sensors.
My limited runs normally should I get an additive for the fuel which one? I fill up with high-octane gas all the time.
I did a search on the forum and will start with the least expensive fix first then work down the line
any suggestions
Old Oct 1, 2017 | 12:33 PM
Default Re: Help with P2098 CODE
any suggestions
The problem is often an exhaust leak. The manual says not to add anything to the fuel. I consider these additives a waste of money. Good fuel with the additives in it is good enough.
Google search the code and see what they say for confirmation of my input and other causes.
Old Oct 2, 2017 | 08:30 PM
Padgett's Avatar
Other than checking for an exhaust leak I'd use a scan tool to check the secondary O2 sensors, neither should be moving from the middle when warmed up.
Old Oct 9, 2017 | 10:51 PM
roychez's Avatar
I was able to fix the p2098 code.I pulled the TB out and replaced the O ring. Problem solved. Thank goodness for this forum and all it`s members.
Old Oct 10, 2017 | 08:09 AM
Good news !! Thanks for reporting back.
Old Oct 10, 2017 | 08:29 AM
Kingdav1954's Avatar
Can you tell any difference in idle smoothness, throttle response, acceleration, or overall performance?
Old Oct 10, 2017 | 08:58 AM
Padgett's Avatar
Must admit to a little confusion here. By the mention of an O-ring I assume TB means throttle body but am at a loss why it would only affect one bank and not both. Why ?
For things like this have always felt that something affecting both banks was intake and only one, exhaust side but this is evidently not so. Ignorance is curable..
Old Oct 10, 2017 | 11:17 PM
roychez's Avatar
The old T.B. O ring had wear and I saw a crack or small grove. I cleaned the T.B. base and where it mounted on the engine. Acceleration was better and much smoother. I really don`t know why it worked and why no more codes. My logic was to do the things that`s least expensive. The sensors were $70+ each.
Old Oct 11, 2017 | 07:33 AM
JohnGiaccio's Avatar
Roy,
Good catch with that O ring. I want to ask you: is that between the Throttle body and the manifold? Where did you get the O ring? Through M/B or Chrysler?
All the best!
John
Old Oct 12, 2017 | 10:00 PM
roychez's Avatar
It`s mounted on the rear of the engine.
O ring from Mercedes was $48.00 Rock Auto $7.00 I had to wait 4 days it was well worth the wait. I also changed out my 2 air filters.
My Crossie is rocking and rolling down the road without that check engine light on. Search the forum for step by step instructions...
Old Oct 13, 2017 | 09:07 AM
Well done Roy!!! Safe travels.
