m5-.80x16mm aluminum torx head cap screww
Old Jan 22, 2018 | 01:20 PM
simba4536's Avatar
Default m5-.80x16mm aluminum torx head cap screww
Does anyone have the part number for this item, or know where it can be purchased. It is used to secure the return oil covers on my 2005 roadster
Thank you
Old Jan 22, 2018 | 01:51 PM
Steve Jr's Avatar
Default Re: m5-.80x16mm aluminum torx head cap screww
Are these for the valve covers on the engine?
Old Jan 22, 2018 | 02:37 PM
simba4536's Avatar
Yes, they are the smaller covers that allow for oil to cool before it flows back into engine
Old Jan 22, 2018 | 02:52 PM
These small covers are the MB version of PCV, Positive Crankcase Ventilation, nothing to do with oil cooling.
Old Jan 22, 2018 | 03:22 PM
simba4536's Avatar
Thank you for clarifying the function of the assembly and the links. I would like to effect the repair of the seals and have the correct screw.
Old Jan 22, 2018 | 03:32 PM
simba4536's Avatar
I used the forum member" MikeR " diagram it is has a part name and the torque specs but no part # , or where to purchase the aluminum part, tried to find on MB but no hits using part description, hence the need for a part #.
Old Jan 22, 2018 | 04:55 PM
Try here!
https://www.albanycountyfasteners.co...p/1099-008.htm
Old Jan 22, 2018 | 07:24 PM
simba4536's Avatar
Thank you.
Old Jan 22, 2018 | 09:30 PM
Thank you.
There was a post here a few weeks ago and it said if you asked a certain company they would send you some as free samples.
Old Jan 23, 2018 | 09:56 AM
simba4536's Avatar
Found part # for m5-.80 x16mm it is 05102924AA
https://www.moparpartsoverstock.com/...5102924AA.html
cost is $3.57
Thank you all that responded, hope this will help other CF owners
Old Jan 23, 2018 | 10:52 AM
If that is per screw that is very expensive. On the other site you can get 25 for $7.00 plus shipping. About $13.00 for 25 or about 50 cents each.
Old Jan 23, 2018 | 08:31 PM
Steve Jr's Avatar
And I'll go in halves, if your willing to fool with it...
Old Jan 24, 2018 | 11:17 AM
Is there any problem with using stainless steel instead of aluminum?
Old Jan 24, 2018 | 11:35 AM
Not that I know of, I have had SS screws in for about 5 years now and no problems.
Old Jan 24, 2018 | 12:11 PM
Should the screws and covers be made wet with a salty solution or any electrolyte you would have a problem. It may not apply to you with the salt nor I as it never sees the winter but for others it may well be a bad idea.
If they were tightened too much the threads in the covers would tear out.
If you want to use stainless screws get ones that are plated.
Play it safe, get aluminum screws.
My 300 has aluminum covers behind the brakes and they were held on with steel screws, the salt attacked the aluminum around the screw head and ate through it leaving aluminum washers under the screw heads, they later went back to steel shields.
Galvanic corrosion is what caused the problem, another fine example of Chrysler engineering that was probably dictated by some ignorant accountant who was paid to save money.
Old Jan 24, 2018 | 02:52 PM
TRUE : Should the screws and covers be made wet with a salty solution or any electrolyte you would have a problem. It may not apply to you with the salt nor I as it never sees the winter but for others it may well be a bad idea.
VERY TRUE : If they were tightened too much the threads in the covers would tear out.
NeedsWings
Jun 8, 2019 05:45 PM
srtsmally
Mar 17, 2013 07:41 PM
stlouistrucker
Sep 26, 2012 08:05 AM
Holycrap
Oct 9, 2010 01:19 PM
Fenwick223
Jul 25, 2007 02:03 AM
