Slight vibration issue
Old Oct 14, 2018 | 03:19 PM
Tom3120's Avatar
Default Slight vibration issue
I’ve had my roadster for a couple months now I have new tires, brakes and rotors. Only have about 1000 miles on them. I’m noticing a very slight vibration between 35-45 mph. Goes away other than that range. Maybe it’s always been there but I’m just now starting to get to know my car better. I’m thinking of having the wheel balance rechecked. Is there something else that I should look at.
Old Oct 14, 2018 | 04:16 PM
Default Re: Slight vibration issue
The first thing I would do is have them rebalanced. The problem having them rebalanced at the same place may give you the same results unless they have more than one balance machine. Ask them when the last time the balance machine was calibrated. Most machines only take a few moments to calibrate. Although they are new tires, doesn't mean you can't have a defective belt in the tire.
Good luck, James
Old Oct 14, 2018 | 04:18 PM
maggy55's Avatar
I notice a bit of vibration when I first start driving, then it goes away. I think mine is just a flat spot on the tires from sitting. I don't know if this is the same thing your experiencing.
Old Oct 15, 2018 | 08:56 AM
Cobrasrt8's Avatar
Having them balanced again may or may not help. Tires have a heavy spot on them which is marked on the sidewall by a red or yellow dot. That dot should be opposite if your valve stem to counter balance each other. If they did not do that I would suggest to them to turn the tire on the rim and rebalance.
TiredRetired
May 5, 2013 11:07 PM
southtexas
Jan 24, 2009 06:05 PM
InfernoRedXfire
Dec 22, 2008 04:26 PM
christo76
May 10, 2006 09:48 PM
andrew
Other Cars Etc
Mar 7, 2006 08:17 PM
