can somebody help ID this part??
Old Dec 21, 2018 | 04:58 PM
mmichleski's Avatar
Default can somebody help ID this part??
** PICTURES ATTACHED BELOW **
hello! today I was cleaning the wheels on my 2004 crossfire. When I reached the driver sides rear wheel I noticed something odd. I found a pretty rusted/corroded tube that looks like it connects to the brakes. the tube is located right above the brake rotor, a tad further into the car.
I’m guessing it’s the brake line?? I went over to the other rear wheel and that line is in much better condition.
can anybody tell me what this part exactly is?
has as anybody on here ever had this replaced??
any my info would be greatly appreciated :-) thank you!!!
Old Dec 21, 2018 | 10:50 PM
Larry Hitze's Avatar
Default Re: can somebody help ID this part??
There are no picture attached that I can see.
Old Dec 21, 2018 | 11:00 PM
Could it be the brake pad wear sensor?
Old Dec 21, 2018 | 11:06 PM
Emergency brake cable?
I have now seen the pics in your gallery and concur with James1549s opinion it is the sway bar.
Old Dec 21, 2018 | 11:11 PM
You need to put a light on the object. It is hard to see but looks like the sway bar?
Old Dec 22, 2018 | 11:06 AM
mmichleski's Avatar
hello! sorry about that. I tried posting pictures through my mobile phone however I did not work... here are the pictures!
any help would be very much appreciated... I am VERY grateful for you people & this forum :-)
rear driver's wheel
a bit closer...
the culprit!
the culprit pt. 2
Old Dec 22, 2018 | 11:10 AM
mmichleski's Avatar
I thought that this part was a rubber black hose, however its actually metal.
I see people saying it may be the sway bar? has anyone here had a sway bar replaced before?
Old Dec 22, 2018 | 11:21 AM
mmichleski's Avatar
found this sway bar kit off of eBay. Haven't purchased anything yet... just wanted some opinions.
https://www.ebay.com/itm/2004-CHRYSLER-CROSSFIRE-112-REAR-SUSPENSION-SWAY-STABILIZER-BAR-ANTI-ROLL-ASSY/173625309703?fits=Model%3ACrossfire%7CMake%3AChrys ler&epid=5025199751&hash=item286cdffa07:g:xlEAAOSw E~1b4LAS:rk:6f:0#viTabs_0
or maybe this one :-)
https://www.ebay.com/itm/MERCEDES-R1...XCoa:rk:1:pf:0
Old Dec 22, 2018 | 12:38 PM
We still need better pics to see exactly what is going on and what is broke or missing.
Old Dec 22, 2018 | 12:49 PM
https://www.ebay.com/itm/2004-CHRYSL...:pf:0#viTabs_0
Try to look for a camera that will take decent picture first.😀
Old Dec 22, 2018 | 03:05 PM
mmichleski's Avatar
thanks for your reply. here is the best picture I can take (it gets tricky angling the camera that far into the wheel)
thanks to you guys, I'm almost 100% certain that the mystery part is the sway bar.
it looks pretty corroded & rusted.. there also looks to be a hole protruding through which worries me.
the 2 other smaller arm pieces that connect this black bar to wheel look to be in fine shape.
would you guys recommend replacing this rear sway bar before something goes very wrong?
thanks for all your time! :-) -Matthew
Old Dec 22, 2018 | 03:07 PM
mmichleski's Avatar
I really appreciate all your contribution to this forum. I was able to fix my RCM , power seat relay & the sticky key fix thanks to you guys!!! saved me so much $$
Lynda
Sep 14, 2012 02:16 AM
durdenss
Oct 20, 2010 11:15 PM
boricua1
Aug 16, 2008 08:01 PM
shubi.s
Jun 16, 2008 10:37 AM
tylerxfire
Feb 5, 2008 10:42 AM
