engine check light on
Old Jan 18, 2019 | 03:30 PM
oldtweety's Avatar
Cool engine check light on
Bought a 2004 crossfire drove it 1 month and light came on P401 or 104. Anyway took our RCM and soldered 3 problem sites. Put it back in and light went off for a week the came back. Any thoughts.Also do I need to clean the pins on all the fuses
Old Jan 18, 2019 | 04:18 PM
Default Re: engine check light on
Yes you are...
Old Mar 16, 2019 | 08:59 AM
afgrc's Avatar
Hello, sorry to resurrect an old post. P0410 is secondary air pump error code. There are three components that contribute to the error. 1, the little blue valve under the engine cover in front of the secondary air pump. Check and make sure the little ball inside is freely moving. 2. The RCM or relay control module, you did a good job by resoldering it, but that's not enough, if the air pump has gone bad you'll need to clean up the number 5 relay (or number one depending on how you view the universe) see video below. 3. The pump itself. As seen in the video my relay was shorted engaged so the pump was always running which contributed to a shortened life. Unfortunately, if your scenario played out like mine, you will likely need a new secondary air pump.
Afterguard
Oct 22, 2012 09:49 AM
new2crossfire04
Dec 4, 2010 05:21 PM
Mr.Troy
May 20, 2010 05:42 AM
mjanowich
Aug 14, 2008 06:28 AM
CHERYLCARSON1
Mar 8, 2007 05:23 PM
