2005 Roadster Problems Starting: P0171 & P0174
Old Aug 10, 2019 | 03:53 PM
eaoporto's Avatar
Default 2005 Roadster Problems Starting: P0171 & P0174
Hey guys! Recently I picked up a 2005 Chrysler Crossfire Roadster. Has 69,000 miles on the odometer, runs great, top functions, I'm in love with the car.
I'm having issues starting, however. Check engine light is on, throwing codes P0171 and P0174. The car cranks for sometime maybe 3-8 seconds, but it turns over and the engine starts eventually. Once it starts it stays running and drives fine. Only one time did the car fail to start.
A mechanic friend has told me it's the fuel pump, and Autozone told me it's the O2 sensor, which I doubt. I've searched the forums and read the likely scenarios as either: the fuel pump, MAF sensor needs cleaned/replaced, or it's the Cam/Crankshaft Position sensor.
I'm going to try cleaning the MAF sensor tomorrow. I don't have access to a lot of tools to do things myself, but I'm super hands on and actually find this kind of stuff fun. I'd like to attempt things on my own within my ability before going to a shop.
Any other suggestions or ideas as to what it may be? Thanks in advance guys
Old Aug 10, 2019 | 04:22 PM
ttmmdd's Avatar
Default Re: 2005 Roadster Problems Starting: P0171 & P0174
Sure sounds like no fuel pressure, check the Schrader valve on the fuel manifold. Just after you turn the key on, push in the pin with your fingernail and see if you have any fuel pressure you should have about 50lbs.
Old Aug 11, 2019 | 11:04 AM
eaoporto's Avatar
When I turn the key on and press on the valve nothing happens, you can hear the fuel pump do something when the key is turned to on, but pushing on the valve no pressure is released.
Old Aug 11, 2019 | 11:07 AM
fuel pump running and no pressure :
1. bad fuel pump
2. clogged filter
3. crimped/ruptured fuel line
4. no fuel in tank
Old Aug 11, 2019 | 11:13 AM
eaoporto's Avatar
The tank was just filled two days ago, so that's solid. Once it turns over it starts, and I've been able to drive anywhere. Could something still be crimped or ruptured with the engine running? There's no smell of gas coming from the car anywhere, we don't think it's a rupture. We have been leaning more and more towards the fuel pump and filter. I may run to an autoparts store and replace it myself today
Old Aug 11, 2019 | 11:47 AM
If you haven't already, go here to find repair manuals and how tos.
orbit398
Sep 24, 2021 03:53 PM
newaustinite
Jul 26, 2019 07:16 PM
drcnh3
Jan 29, 2014 07:50 PM
chasemichaelis
Nov 25, 2013 07:33 PM
speaks2all
Mar 19, 2010 02:50 AM
