Old Aug 10, 2019 | 04:22 PM
ttmmdd's Avatar
ttmmdd
Default Re: 2005 Roadster Problems Starting: P0171 & P0174
Sure sounds like no fuel pressure, check the Schrader valve on the fuel manifold. Just after you turn the key on, push in the pin with your fingernail and see if you have any fuel pressure you should have about 50lbs.
